Rhino Extremely Slow
Hello there!
Rhino is running extremely slowly for me. It runs slowly and stops responding for almost everything I ask it to do especially saving. What is the issue here??
Below I have my comp specs and this Rhino system info as well.
Device name beedroid
Processor AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz
Installed RAM 64.0 GB
Device ID E5F1CDFB-93C1-42A4-ABA1-681CCE4BD05E
Product ID 00330-80003-95483-AA133
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational Lab License, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 16GB, Driver date: 1-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.65
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-12-2024
Driver Version: 31.0.15.4665
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Users\brita\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23328.1417
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
If you temporarily disable Enscape, is it any better?
Hello, unfortunately disabling enscape seems to have no effect.
Hmm, I don’t know then, your computer seems to be largely powerful enough to run even big files and the drivers are up to date…
Does this happen with all files, even simple ones?
Yes! Extremely simple ones, but this file is that latest one I have been working with, it has a lot of geometry but it is all simple geometry, I don’t understand what could be causing this issue.
test_loft_sldw_repaired.zip (22 Bytes)
Hi -
It doesn’t look like there is anything at all in that zip file.
Assuming you are saving on your local SSD, do you have plenty of free space on the drive?
Sorry about that! Just realizing the file is too big to send, its 697 MB, is that unreasonable?
I actually don’t save anything to my hard drive, I have an external hard drive and I save to my cloud as well.
Try disable file compression in advanced options.
Hi -
I wouldn’t say that’s unreasonable, but, depending on the number of objects in that file, could certainly attribute to slowness. You could upload your file so that we can check if there’s something out of the ordinary going on. Make sure to mention this thread in the comments field.
I think Riccardo might on to something.
Turn off file compression.
Also, try saving to your local SSD. That should be WAY faster.
