Hi Guys,
I have an issue where I want to ViewCaptureToFile my raytraced image - rather than print screen - and when I do it, Rhino continues to raytrace in the main window and appears to be doing the same task in a ‘progress’ window as well. Ultimately, I would like to save the raytraced image - setting my custom variables (passes, pixels etc…) - while in shaded view or wire frame, so my computer handles it better. Is this possible?
Best,
Felix
I think I’m following you.
You can not have a viewport display in one mode and have it generating a Cycles Ray traced image at the same time.
You would need to leave the Raytraced view alone and work in another view. Maybe it would make more sense to use the NewFloatingViewport command, set it into the Raytraced display and let it cook.
Also, The Raytraced view in V7 will be much faster if you have a display adapter that can do the work. The performance will still suck if you’re running a little under powered Intel chip.
