I hope you can help us with a problem we are having after our IT department decided to upgrade Windows 7 professional to enterprise (because they want to use encryption). After this upgrade, stuff got broken. Visual studio didn’t work any more and also Rhino Scripting fails to open. Rhino itself seems to start fine, but choosing Tools>PythonScript>Edit does not do anything. Trying to run a script (Tools>PythonScript>Run) generates the following dialog box:
Our Rhino version is:
Version 5 SR12 32-bit (5.12.50810.13095, 10/08/2015)
Is there anybody with an idea on how to fix this issue?
Did you install IronPython on your computer (the one that is separate from anything Rhino)? Rhino may be accidentally picking that version instead of the one that ships with Rhino.
The IronPython plugin is present and enabled. We already tried reinstalling Rhino completely. We do have IronPython 2.7 installed separately on the same computer, but that has never been a problem before.
The separate IronPython 2.7 does work from the command line.
This error has also popped up when running the Run PythonScript.
