In an attempt to update IronPython in Rhino 5, I added a later version as a path in the Options menu of the EditPythonScript window. I changed the order so the newest version was above the preset paths. Now when I run the EditPythonScript command in Rhino, the window does not pop up anymore. I already read that changing the preset paths is unadvisable but is there a way it can be fixed? I already tried re-installing Rhino but this did not solve the problem.
Thank you for your help.
Hi Victor - do you have a separate Iron Python installation apart from the one Rhino installs? If so, I think you need to remove that, and possibly reinstall Rhino for good measure.
Thank you for your reply. I have removed the separate installation of IronPython and reinstalled Rhino5. The window is still not appearing after running the EditPythonScript command sadly.
