Python doesn´t work in RH5 SR14
Hi Community,
if i try to open the python Editor in RH5 i get the following informatoin in the command line
Befehl: _RunPythonScript
Unbekannter Befehl: _RunPythonScript
Befehl: _EditPythonScript
Unbekannter Befehl: _EditPythonScript
recently i did an Installation of IronPython 2.7.5.
But the Problem allready appeared bevor.
Does anybody know how to solve this?
thank
regards Franz
Hi Franz,
I would still try uninstalling IronPython.
Alain
Hi Alain,
thank you for the quick respond.
unfortunately the problim is still there.
i cant open the Editor. It says something like can´t find the Editor.
Franz
Sorry you’re having that problem. After uninstalling IronPython could you try re-installing Rhino?
Hi Alain,
could it be that Python doesn´t work on certian education Versios of Rhino?
Franz
No. Educational versions are completely the same as commercial ones.
Which version are you running?
I think performing a re-installation of Rhino will help. Can you try that?
Also, make sure that the IronPython plug-in is not disabled in the Options -> Plugins option dialog.
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi Giulio,
im using this Version:
Version 5 SR14 64-bit
(5.14.522.8390, 22.05.2017)
Studenten
SN: 4-1500-0103-100-0058825-28773
best Franz
i haven´t found any Python Plug-in in the Plug Library (Tools/Options/Plug-Ins)
It should be called “IronPython”. Make sure it’s enabled. If you don’t find it, this definitely justifies a re-installation!
