Rhino PDF in Rhino 8 destroying polylines
Hi everybody. Last week a file suddenly started to fail to print in Rhino PDF. A lot of polylines, some of them even embedded into blocks, are not rendered correctly in PDF, even some of them are break apart. I tried to export the objects into othere files, save small, etc. And nothing worked. The last solution for me was to explode the polylines :frowning:
I’m attaching a screenshot showing only some of the poly lines with issues, but it was a big problem, there were many more.
Any suggestions to overcome this?
Thank you very much
Hi -
I’m afraid it is close to impossible to debug an issue from a screenshot. Would you be able to post a simple file that shows the behavior.
In addition to that, please run the Rhino SystemInfo command and copy-paste the result here.
Thanks,
hi @wim . Thank you for you reply.
I’m attaching a simplified version of the file, although there are so many more objects with that odd behaviour.
REPORTE_BAD DRAWING.3dm (754.5 KB)
Rhino 8 SR2 2023-12-12 (Rhino 8, 8.2.23346.13001, Git hash:master @ dbefe46c12cda06610a9ab683a211aa3d16f0030)
License type: Evaluación, build 2023-12-12
License details: Cloud Zoo
Expires on: 2024-02-14
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 24Gb)
.NET 7.0.14
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 4-11-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 11-13-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.98
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-13-2022
Driver Version: 31.0.15.2698
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\Miguel\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23346.13001
Hi -
That one looks fine when I export that to PDF here:
REPORTE_BAD DRAWING.pdf (26.1 KB)
I would suggest updating to the latest 8.3 service release candidate. You’ll need to change your update frequency in the Rhino Options to get that.
Hi @wim … Thank you for your time… Unfortunately after updating to the latest Service Release Candidate, I’m still having this wrong PDFs with RhinoPDF. I even made a completely new installation of Rhino. And still failing…
Any other suggestion?
thank you in advance
REPORTE_BAD DRAWING_2.pdf (29.1 KB)
Rhino 8 SR3 2023-12-26 (Rhino 8, 8.3.23360.13001, Git hash:master @ eb46d24144907458c3e3bb82d501b5499b1c4a49)
License type: Educacional, build 2023-12-26
.NET 7.0.14
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Hello Everybody!.
I’m still having this odd behavior with my drawing. I’m attaching both the rhino file and a PDF made with Rhino PDF… It is a simple polyline, and it is not printed correctly. I have already made a fresh new installation. and nothing. Any suggestions?
Thank you.
MISTAKE.3dm (53.0 KB)
MISTAKE.pdf (1.4 KB)
.NET 7.0.14
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.3.23360.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.23360.13001
Please install the latest Rhino 8 service release 3. There is one from January 2nd that should fix this issue
Thank you. It is indeed fixed now.
