I think that usually there is no issue with pdf object since a while but today I found errors in my drawings.
I can’t figure out how to print all the lines of my layouts. Maybe since last update few weeks ago.
Here is my python code and a stripped down rhino file.
Any idea ?
This could be a regression in the Rhino print code, as even printing by hand does not work from your file, I’m not totally sure though as i mostly print in frame. At least there is definitely a bug in the print preview → result portion:
When modifying a layout format through _LayoutProperties, when units are changed, the width and height values do not scale themselves to the units selected. It seems to be related to custom size format.
Regards.
update : according to release 2019-11-18
LayoutProperties command seems to work know.
But rhino pdf still not working. I’m able to print through PdfCreator though (virtual pdf printer).
