PDF Broken Lines Rhino8
Wondering if people are seeing this happen in some PDF outputs?
Notice that one of the lines gets sent to a new end point in the top left corner.
Here’s the intended output:
To fix, I have only found one solution; Explode, convert, Join; Or simply exploding the geometry does the trick too. Curious thing is simply exploding, then Joining brings back the line going the wrong direction again
PDF Line Output Example.3dm (70.1 KB)
PDF Line Output Example.pdf (30.9 KB)
Have you ever tried SimplifyCrv ?
We do regularly, yes.
Does produce a slightly different result using it on this example:
hi @Vomela thanks for reporting,
I can reproduce that issue here.
RH-79094 Print to pdf: closed polyline does not render well
Cool, Thanks Gijs.
This isnt the place, but updated to:
Today.
Text Panel is a bit barren looking now.
Yep, reported several times…
I love how active people and developers are for Rhino.
We came from a wealth of other programs (Mainly AutoDesk) and support for those are nothing compared to Rhino’s team and users.
The developer API’s are also very nice and has helped us greatly.
Some deserved Praise was due.
yes, this one is on the list RH-79011 Text Panel does not show any option
RH-79011 is fixed in Rhino 8 Service Release 3 Release Candidate
RH-79094 is fixed in Rhino 8 Service Release 3 Release Candidate
Updated:
I tested on the original upload i sent and all good on that one now.
See attached example that has the same problem with this build.
Model Space:
PDF Output:
Files:
PDF Line Output Example 2.pdf (4.2 KB)
PDF Line Output Example 2.3dm (66.6 KB)
Thank you
Thanks, I reopened that issue with your new files attached.
Appears to be fixed up, thank you.
