Rhino - Not responding mode
I am facing issue in opening rhino files. It keeps on going in not responding mode and then every time only when I have to shut down and start the laptop, rhino opens. But again as I try to open any rhino file, it goes into the not responding mode. Has anybody else faced similar problem ? Could it be a rhino 8 issue ? Any suggestions ?
Thanks
Hi Ritu Agrawal,
Please run SystemInfo in your Rhino command line and post the results.
This will provide what Rhino Version you are using, your video card as well as list any 3rd Party plugins that you are running.
Another aspect is your network environment, are these files hosted on the cloud or server?
Does this happen with blank files or particular files? If so can you post an example? Thanks
