Rhino Line weights To PDF
I am currently using the most updated Rhino for Rhino 8. When I add line weights to each of my layers they show up correctly in rhino. In my print layout the weights are also correct. But for some reason when I print the pdf from print layout the only line weights that actually come out are the cut lines and everything else is the default weight. Is there any way to fix this? This issue didn’t happen before so I have no clue how to fix it.
Hi Ali,
There are several ways to control line weights in Rhino 8 Can you post a small example of your of your file and your Rhino systemInfo? Thanks
Sorry for the late reply, soon after my file started working again normally. However, I thought I ran into the issue again but I figured out what the problem is. For some reason, when in rhino I can set things below .04 mm (.12 pts). It shows me with print display that it is working. The second I export it as a pdf then open in illustrator, it decides that every line weight that is below .04 mm defaults to .12 pts on illustrator. All line weights above that are fine but for some reason it will now allow anything below .04 when opening the pdf in illustrator.
