With some documents the programme becomes unworkable on due to the lag.
I am primarily using the front view window to draw elevations on a building.
When the point cloud is enable the lag is unbearable but there is still lag when it is disabled.
I have been working on documents (the same way) and most are fine. If I try to re-create the document, the same issue happens.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 3-16-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Laptop GPU (NVidia) Memory: 4GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2023
Driver Version: 31.0.15.3742
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Veesus Point Clouds For RHINO\Veesus.dll “Veesus Point Clouds for Rhino” 2023.3.9730.32757
easiest test is to disable the veesus plug in to isolate the issue… if rhino speeds up immediately, we know the problem lies with veesus and we need to contact their developer and get them involved.
if not, then we have a rhino problem and we need to dig deeper.
either way we need to figure out where to look first.
go to tools>options>plugins>veesus > and uncheck the enable box. then restart rhino.
if you pull the 2nd monitor does it speed up? you have 4gb vram which is enough for 1 monitor, but you are 4gb shy for 2 monitors ( system requirement is 4gb per monitor)
