Rhino 7 lagging, freezing and not responding
Hi All,
Was hoping to find a sollution to get rid of Rhino 7 freezing, lagging and not responding.
Already turned off the GPU tessellation and have set antialiasing to none… none of this helps.
Hardware should be fine… could you guys help me out?
Systeminfo shown below:
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Commercial, build 2020-12-08
License details: Cloud Zoo
Windows 10.0.19045 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2023
Driver Version: 31.0.15.3598
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
Hi @Harm_Backx
You are on Rhino 7 Service Release 1 :grimacing: The latest SR is 29, and you’re basically 2 ½ years worth of bug fixes and updates behind. I’m sure an updated version will fix at least some of your problems, if not all :slight_smile: Go to Help>Check for updates for more.
HTH, Jakob
Hi Jakob thx for your reply! Just installed updates to version 7 SR29. But no difference in the lagging and freezing experience…
Any additional tips? :stuck_out_tongue:
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03001, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: Commercial, build 2023-04-17
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
OpenGL Settings
Safe mode: Off
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.29.23107.3001
Hi @Harm_Backx It looks you have 3 monitors connected to your M4000. That’s a lot of displays to handle. Does your problem persist if you only connect one monitor?
Unfortunately the Quardo M4000 is a very old video card with worse performance than a budget gaming card today. And you have 3 monitors connected? Without knowing more, it would seem it’s just not up to that.
Hi Gijs, thx for your reply. Yes, it becomes slightly better if only connect 1 monitor but the freezing and lagging continues never the less.
What graphics card would you recommend to have a proper functioning system?
I still have that card in use as well, connected to a single 4K screen and it works just fine. But it depends on how you are using Rhino. I would not be surprised if this is something related to your file rather than your hardware. If you want, I can have a look at the file that is lagging. Confidential files can be uploaded here, pls link back to this thread.
Just get the best GTX card you can, but I don’t know if the rest of your system is up to snuff enough to not be a bottleneck or if the problem is just that your Rhino files have something making them unnecessarily complicated.
