Rhino 6 ran out of memory
errorrhino
When I attempt to open the file, rhino prompts the message:
A memory allocation failed and Rhino will close.
Rhino attempted to save the current model on your desktop in
*RHINO_EMERGENCY_SAVE.3dm *
*This file may be damaged and should be used as a last resort. *
Restart your computer.
I’ve tried opening the emergency save, but the problem persists.
I’ve tried the different solutions presented in this thread, but none of them seem to work. Windows found no errors in my computer’s memory and the only plugin I have is vray and attempts to update both rhino and vray proved unfruitful.
The file was working just yesterday, and I have not installed anything since then.
Hopefully, someone has a solution.
Thanks in advance.
_systeminfo
Rhino 6 SR31 2020-11-10 (Rhino 6, 6.31.20315.17001, Git hash:master @ ff08c426b1ef7d3a1c50a01e5e87220a68a9f815)
License type: Educational, build 2020-11-10
License details: Cloud Zoo. In use by: Anders ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-6NHDA3T
Hybrid graphics system.
Primary display: Intel® HD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-11-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 8-12-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.06
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-12-2020
Driver Version: 27.21.14.5206
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.31.20315.17001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Hi Anders -
Can you post or upload the original file so that we can check if this issue is system-related or if there’s something going on with that file?
Hi Wim,
After performing a clean install of rhino6 the problem is gone. I’m not sure what caused it since I got the error on certain files while others worked as usual. So it was not one specific file.
I’ll report back if I get the error again.
Thanks for your reply.
