Rhino inside revit
i’m using this nodes to get the family components from revit to rhino from Rhino inside revit, it is working perfextly fine, but after importing the elements into rhino, the file is getting too heavy, it has a python script in it.
is there any possible solution, that the elements after importing into rhino will be a smaller file and not larger. i also tried making the file smaller in rhino, also tried purge. nothing is working. as my revit file size if its 120mb, its converting to rhino about a 1 GB.
anyone with any solution…
revit to rhino.gh (16.3 KB)
Bringing the objects in as blocks would improve file size (right click Elements and Bake for a quick test).
Are there are a lot of radiused elements? What are the tolerances in your Rhino document?
i tried doing that as well, didn’t work. regarding tolerances i tried changing, doesn’t helps a lot. its like i have a curtain wall in my model, so there are around 15,000 mullions in the whole model, that is causing the model to be hit a Gigabyte.
I assume these have a lot of detail.
What is the workflow? are you bringing to Rhino for fabrication or coordination purposes?
One option is to use the bounding box representation and bake with the attributes you need for coordination.
the thing why i’m doing this all is, i want to convert it into a glTF format which can be done through rhino. but i have revit files with me. so trying to convert it into rhino first, and then to GLTF.
didn’t get the Bounding box representation thing. can you please elaborate on it more.
