Revit to Rhino element number issue
How many numbers of elements can be exported to rhino? I want to know the reseaonable number. It looks very difficult if huge elements. thanks.
I don’t know of any limit, you want to be judicious of course. A good example is a large structural model with detailed connections (IFC import from tekla) and you want to coordinate with your model. Initially you could do bounding boxes of all the Revit objects and their useful data. Typically worksessioning in the large file to a working file with clipping planes. Linking in a higher detailed model if need be.
thanks for apply. I’ve found it very hard if exporting 100000 geometries, but very smooth if 1000. I want to know is there a reseaonable range suggestion if any. thanks.
If the larger number is taking too long try using the Partition List something like this to find the right amount for your situation.
Note the content cache is set to Bake.
Thanks Japhy
