Hi All,
I am currently trialling and testing some workflows in Rhino.Inside.Revit and have the following questions:
Is it possible to create an element like a column (or any element) in rhino (see attached) convert it to Revit using Add Geometry DirectShape via grasshopper to have the same property identity data like a column created natively in Revit?
In attached is the property data of a natively made column as opposed to the rhino made column (on the left)
Thanks.
