Need help with Native Revit Extrusion through Rhino.inside
Hello there,
I am wondering if there is a way I could regenerate these cubes as native revit family extrusions or in-place models that still gives you the control (modifying the profile) in the Revit project environment?
Or, is it possible to first create a Revit family Cube and then relocated them to the desired locations like the image below through Rhino.inside ? I assume I can somehow select the revit family in grasshopper then populate them to the desired locations in Revit. Thank you in advance !
A great place to get started is the Rhino.Inside.Guide.
You can also check this post with similar idea on placing blocks, after going through the above guides to get an understanding…
Thanks Japhy, I will go through these tutorials again and see if I can find the answer I need !
Thanks Mohamed, this is very useful information !
