Rhino inside revit issue
I can not expand the geometry in Revit. I created the house in grasshopper but can not expand in Revit. As the picture shows there suppse be a floor, but can not show on Revit.
I made some components that want to move geometry and change material, but I can not move geometry and change its material in Revit.
Jeffrey Song House z5331889 code 2270.rvt (16.2 MB)
gh 2270 new.gh (1.3 MB)
Moved to Revit category.
I used Add Geo DirectShape in Grasshopper only shows in Rhino But can"t show in Revit.
Make sure your Units are corresponding in Revit/Rhino
https://www.rhino3d.com/inside/revit/1.0/guides/rir-grasshopper#unit-systems
I all use meter in Rhino and Revit.
Does it work in a new file for you?
No. I tired in a new file it’s the same.
New file is a default revit template or a custom file? I’m not able to repeat this so far.
It works in the default temple, but how can I select Geo in Revit? like I want to move my floor in revit
Hi Japhy,
Thank you. It works in the new File but How can I select this floor?
The element tracking guide explains your options, let us know if you have any questions.
https://www.rhino3d.com/inside/revit/1.0/guides/rir-grasshopper#element-tracking
