I added rhino’s geometry to revit using rhino.inside. After my adding I can’t pick it up on revit editor window. Also I cant’t see that model at elevation window. What’s the problem ?
- You have select pinned objects turned off. Element Track objects are generated pinned in the Revit Document.
- The elevation is mostly being cut in front of the element.
Thank Japhy for your comment.
I solved unseened elevation problem. Also I can pick my geometry up at revit.
But my work is to make floors on it. Still I can’t select it and add floors on.
I think my grasshopper process has no problem as you know.
How can I control my objects at revit state or modify them ?
I will need to see how you are creating these to be able to help.
There is only one way to create Revit Floors that are editable; that is via the Add Floor
component.
You can create direct shapes on the Category of Floor but they won’t be editable or have a Floor Type.
