I tried both in my Revit 2018 & 2019 but got the same result. I don’t get the two options from the first image:
“Set one Revit Element” & “Set Multiple Revit Elements”.
Did I miss any step, did I choose the wrong component? Or do I have to reinstall, or use a different version??
Yes. Figured that out eventually. I am currently starting with Grasshopper (previously doing Dynamo with Revit) and found there’s a lot of options in Grasshopper and most component’s name are completely different.
Is there some sort of a “Grasshopper Component Dictionary” listing all OOTB components and their description + samples?
Also, I believe that the components listed there are only those in Rhino.Inside-Revit.
I was hoping to find a dictionary for the default components in Grasshopper for Rhino (without the other packages installed)
