Hi everyone,
My Rhino.Inside doesn’t work even though the update has been installed !
As you can see on the imageq bellow the last version of Rhino.Inside is installed and when i run it on Revit it not work and indicate me that an old version is installed !!
Do you have a solution please ?
Thak you for your reply,
Check that you don’t have two different version installed. I had a similar issue to this and I uninstalled all of the RIR plugins (I had two installed, an old one and a newer one) then installed the newest one from the website.
Hi @devin_jernigan,
exactly, it’s work now !
thank you very much
How do you uninstall both plug-ins?
I had two of them in Add/Remove programs in Windows system settings
