Rhino inside how to import model into revit and pick wall by face
Does anybody know how to use rhino inside and import model from rhino to Revit to pick wall by face?
I tried direct shape by category. It seems like that in this way, the shape is a not editable or readable geometry in Revit.
Moved to Rhino.Inside.Revit category.
@yliu Indeed, directshapes are not editable inside Revit. They’re a method of supporting custom geometry (that is categorized correctly) in Revit. If you need native Revit walls, you can use the “Add Wall” component that takes a curve and constructs a wall (of the given type) over it.
See
https://www.rhino3d.com/inside/revit/beta/guides/
https://www.rhino3d.com/inside/revit/beta/samples/
