I’m trying to edit the way a material graphic shows on a particular surface. I’ve had this problem with other surfaces and I’m wondering how can I edit the surface UV to make graphic properties uniform? See screenshot and file embedded. Thank you MaterialRIR.gh (17.2 KB)
I guess manually rotating them is not too painful. The only thing is that you have to unpin the element which would then remove the tracking on the element.
