When I place a curtain wall either by drawing it or assigning it to a curve Rhino grays out. It looks like Render Mode while being in Shaded Mode. Also, I am unable to select anything, and pressing Enter or Esc does nothing. I have to Ctrl Z to get out which undoes the curtain wall not allowing me to place any. Is there a simple setting or step that I’m missing?
Hi Ethan, can you send me the model to visualarq@asuni.com? I’ll check it out and try to figure out what’s happening.
Thanks,
The first image shows the result of placing a curtain wall. If I change the curtain wall height all that shows up are the few vertical mullions. It’s hard to see, but the xyz axis guide explodes away from the bottom left corner. Again the major concern is once I apply the curtain wall I can not edit anything.
Thanks
Hi Ethan, I got the file thanks. I get this weird behaviour as well. This problem is fixed in the 2.0 Beta version (http://www.visualarq.com/download/beta/), but we will investigate if there is any workaround to avoid it in the current version.
Regards,
