Rhino freezes when opening File Explorer dialogs (Import, Open)
Hi everyone,
I am experiencing a freezing issue in Rhino whenever the Windows File Explorer dialog is triggered. I would really appreciate any help or insight.
Issue Description:
  • Rhino freezes/hangs indefinitely the exact moment the file dialog opens (e.g., when clicking File > Import, Save, or Open).
  • Dragging and dropping files (tried to import dxf file) directly into the Rhino viewport also causes Rhino to freeze.
  • Opening files in other software (like ArchiCAD) works perfectly, so Windows File Explorer itself appears to be working fine.
What I have already tried without success:
  1. Safe Mode: The issue still occurs in Safe Mode.
  2. GPU / Display settings: Turned off Antialiasing and GPU Tessellation in Options > View > OpenGL.
  3. Repair & Reinstall: Performed a Repair Install via Windows Control Panel, and ran Rhino as Administrator.
  4. Windows Explorer Tweaks: Cleared Quick Access history and disabled cloud drive sync (OneDrive/Dropbox).
None of these steps resolved the problem, so any suggestions on how to troubleshoot this further would be greatly appreciated.
Thank you!
Hi Naoki -
Please run the Rhino SystemInfo command and copy-paste its output here.
When Rhino freezes, does it recover after a while?
Hello I am having the exact same problem. And answering Wim, rhino doesn’t recover after a while. It just keeps freezed
Hi John,
What is your SystemInfo?
Hello Japhy,
this is my syteminfo:
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Evaluation, revisión 2026-09-08
License details: Cloud Zoo
Expires on: 2027-01-04
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.31
Computer platform: LAPTOP - Unplugged [93% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-28-2020 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 4-1-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 592.27
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-1-2026
Driver Version: 32.0.15.9227
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “NavegadorWeb”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Renderizado de Rhino” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
Hi John -
To troubleshoot this issue, please disable this plugin in the Rhino Plug-in Manager and restart Rhino. Does that make the problem go away?
Thanks for the fast answer.
I did it. I unabled the vray in the plug-in manager and still doesn’t work..
Lets create a dmp file and try and see where it is hung
