Rhino fails opening file
All of a sudden Rhino doesn’t open the files I just saved.
Rhino itself doesn’t crash but the window just closes without error message. Sometimes I’m left with an empty “Classes” window.
When I reinstall Rhino it works once, then I get the same result.
If I delete
~/Library/Preferences/com.mcneel.rhinoceros.7.plist and ~/Library/HTTPStorages/com.mcneel.rhinoceros.7/ it works once. But after i close Rhino or the document, it won’t open again until i delete the library files again…
It doesn’t matter what files. I created an empty one with just one simple box. Still the same result.
I can create new files. But I can’t open existing ones.
I’m on macOS Monterey 12.4 (21F79)
SystemInfo:
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09002, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Commercial, build 2022-07-12
License details: Cloud Zoo
Apple macOS Version 12.4 (Build 21F79) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,1
Language: en
AMD Radeon Pro 5300M OpenGL Engine (OpenGL ver:4.1 ATI-4.8.54)
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.1
  Shading Language: 4.10
  Z-Buffer depth: n/a
  Total Video Memory: 4080 MB
  Graphics: AMD Radeon Pro 5300M
  Displays: Color LCD (264dpi 2x), DELL U3219Q (140dpi 1x)
Graphics processors
  Intel UHD Graphics 630 (1536 MB)
  AMD Radeon Pro 5300M (4 GB)
    Color LCD (1792 x 1120 @ 59.00Hz)
    DELL U3219Q (3840 x 2160 @ 60.00Hz)
USB devices
  Apple: composite_device
  Apple Inc.: Touch Bar Backlight
  Apple Inc.: Touch Bar Display
  Apple Inc.: Apple Internal Keyboard / Trackpad
  Apple: Headset
  Apple Inc.: Ambient Light Sensor
  Apple Inc.: FaceTime HD Camera (Built-in)
  Apple Inc.: Apple T2 Controller
Bluetooth devices
  None
Third party kernel extensions
  com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
  com.paragon-software.kext.VDMounter (4.2) 3F301F93-CB8D-3149-8C74-D68B3D1C6D52
  org.virtualbox.kext.VBoxDrv (6.1.32) 2966CECD-ED9D-33B1-9B19-35D5B2F3C2A3
  org.virtualbox.kext.VBoxUSB (6.1.32) 2A227B02-53F7-3AC9-8633-3DA6BC2C99F6
  org.virtualbox.kext.VBoxNetFlt (6.1.32) FCFA4205-F86E-3847-87F9-FD20D97978B2
  org.virtualbox.kext.VBoxNetAdp (6.1.32) 596D7961-E512-363D-B8C0-12F4B22D8678
Third party plugins
  /usr/lib/swift/libswiftCloudKit.dylib
  /usr/lib/swift/libswiftCoreData.dylib
  /usr/lib/swift/libswiftFoundation.dylib
  /usr/lib/swift/libswiftAppKit.dylib
  /usr/lib/swift/libswiftContacts.dylib
  /usr/lib/swift/libswiftCoreML.dylib
  /usr/lib/swift/libswiftVision.dylib
  /usr/lib/swift/libswiftNetwork.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
  /usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
  /Users/felixg/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/AsuniClasses.Common.rhp	"LayerClasses"	0.1.0.0
  /Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	7.20.22193.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	7.20.22193.9002
  /Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp	"Displacement"	7.20.22193.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	7.20.22193.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	7.20.22193.9002
  /Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	7.20.22193.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	7.20.22193.9002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	7.20.22193.9002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	7.20.22193.9002
  /Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	7.20.22193.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	7.20.22193.9002
RhinoLog:
❯  /Applications/Rhino\ 7.app/Contents/MacOS/Rhinoceros -RhinoLog
2022-07-29 11:01:46.064 Rhinoceros[11409:506630] < InitWGLExtensions (RhWGLExtensions.cpp:853)> Begin InitWGLExtensions
2022-07-29 11:01:47.505 Rhinoceros[11409:506630] < BuildRegisteredPlugInList (RhinoPlugInManager.cpp:1834)> BuildRegisteredPlugInList [start]
2022-07-29 11:01:49.077 Rhinoceros[11409:506630] < Initialize (RhinoLicense.cpp:917)> Enable license checking
2022-07-29 11:01:49.081 Rhinoceros[11409:506630] < Initialize (RhinoLicense.cpp:947)> Connection established with license manager
2022-07-29 11:01:49.081 Rhinoceros[11409:506630] < Initialize (RhinoLicense.cpp:948)> Get license from license manager
2022-07-29 11:01:49.722 Rhinoceros[11409:506630] < GetRhinoLicenseFromZooClient (RhinoLicense.cpp:1065)> The license is valid
2022-07-29 11:01:49.722 Rhinoceros[11409:506630] < Initialize (RhinoLicense.cpp:954)> The license is valid
2022-07-29 11:01:49.722 Rhinoceros[11409:506630] < Initialize (RhinoLicense.cpp:1037)> END CRhinoLicenseManager::Initialize(), returning true
Jul 29 11:01:54  Rhinoceros[11409] <Error>: kvImagePrintDiagnosticsToConsole: vImageConverter: kCGBitmapByteOrder16Little is not allowed on 8-bit images with pixel size of 32 bits.
Jul 29 11:02:26  Rhinoceros[11409] <Error>: kvImagePrintDiagnosticsToConsole: vImageConverter: kCGBitmapByteOrder16Little is not allowed on 8-bit images with pixel size of 32 bits.
Hi Felix -
Do you remember if you installed anything or did anything on your machine between the time when this worked fine and all of a sudden started failing?
Have you tried to disable the “LayerClasses” plug-in and restarting Rhino?
no idea what might have changed :person_shrugging:
seems, disabling the LayerClasses plugin did the trick though!
