Rhino 7 crashes when I try to open a file only 36.5 mb, but can handle my other 600+mb files
The title really says it all. I have a relatively small file with block references to other larger files. It’s been amazing for the 2+ years I’ve been working on this, but today it crashes any time I try to open it. Tried to reboot, safe mode, etc. but no luck. Using Rhino for Mac “Version 7 (7.5.21100.03002, 2021-04-10)”. Please help, it’s due soon!
Hello - does it crash, or does it hang and never finish opening?
Never finishes opening. After 30 seconds or so it closes out Rhino completely.
Hello - please try: in Preferences > general change the Update frequency to ‘Service release candidate’ and click ‘Check now’ to get a 7.6 build - does that work any better?
Appreciate the suggestion, but unfortunately its still showing the same issue.
Hmmm - Are the linked files all still in the expected locations? Please run the SystemInfo command in Rhino and copy/paste the results here…
And, does Rhino give you a crash report interface? if so, please send one of these in.
Appreciate the quick replies!
System info:
Rhino 7 SR6 2021-5-4 (Rhino 7, 7.6.21124.09002, Git hash:master @ 1a9a92254a9f347268c4c9c7f2dec50bcd90215e)
License type: Educational, build 2021-05-04
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.3.1 (Build 20E241) (Physical RAM: 64Gb)
Mac Model Identifier: MacBookPro16,4
Language: en-GB (MacOS default)
AMD Radeon Pro 5600M OpenGL Engine (OpenGL ver:4.1 ATI-4.4.17)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8176 MB
Graphics: AMD Radeon Pro 5600M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5600M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
Broadcom: Magic Mouse 2
Third party kernel extensions
com.box.filesystems.osxfuse (403.11.2) 0F663263-16BA-340B-843A-9DE80C698E81
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.6.21124.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.6.21124.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.6.21124.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.6.21124.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.6.21124.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.6.21124.9002
Crash Report. (its too long for the space, so I’ve included the parts that looked important):
Process: Rhinoceros [1233]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.6 (7.6.21124.09002)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Rhinoceros [1233]
User ID: 501
Date/Time: 2021-05-10 19:55:50.694 +0100
OS Version: macOS 11.3.1 (20E241)
Report Version: 12
Bridge OS Version: 5.3 (18P4556)
Anonymous UUID: 916DF91D-29D5-A644-D4CF-C159DF6132F4
Time Awake Since Boot: 2500 seconds
System Integrity Protection: enabled
Crashed Thread: 0 tid_103 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
stack buffer overflow
Thread 0 Crashed:: tid_103 Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff20365946 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff20394615 pthread_kill + 263
2 libsystem_c.dylib 0x00007fff202e94ab __abort + 139
3 libsystem_c.dylib 0x00007fff202c3979 __stack_chk_fail + 100
4 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b541fb8c CRhRdkContentNode::CreateInitializedContent(CRhinoDoc const*) const + 456
5 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b541f9bb CRhRdkContentNode::CreateInitializedContentForMerge() const + 17
6 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b540b99e CRhRdkPersistentContentList::SmartMergeContent(CRhinoDoc&, CLBP_XMLRootNode const&, CRhinoFileReadOptions const&, CLBPRhOpenDocStackItem&, CRhRdkPlugInUsedContentNotifier const&) + 278
7 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b54d648b CRhRdkDocument::CImpl::MergeContentIntoDocument(CRhRdkStorage const&, CRhinoFileReadOptions const&, CLBPRhOpenDocStackItem&) const + 277
8 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b54d615f CRhRdkDocument::CImpl::ReadDocument(ON_BinaryArchive&, CRhinoFileReadOptions const&, CLBPRhOpenDocStackItem*) + 1111
9 com.mcneel.rhinoceros.RhMaterialEditor 0x00000001b562d4f7 CRhRdkRhinoPlugIn::ReadDocument(CRhinoDoc&, ON_BinaryArchive&, CRhinoFileReadOptions const&) + 41
10 com.mcneel.rhinoceros.RhCore 0x00000001062d01dc CRhinoRead3dmHelper::ReadUserDataTable(CRhFileReadOptions&) + 1172
11 com.mcneel.rhinoceros.RhCore 0x00000001062d30ce CRhinoDoc::Read3DM(ON_BinaryArchive&, CRhFileReadOptions&) + 1836
12 com.mcneel.rhinoceros.RhCore 0x00000001063b3800 RhinoReadFile(wchar_t const*, CRhinoDoc&, CRhinoFileReadOptions const&) + 283
13 com.mcneel.rhinoceros.RhCore 0x00000001062d1c63 CRhinoInstanceDefinitionTable::UpdateLinkedInstanceDefinition(int, wchar_t const*, bool, CRhFileReadOptions&) + 779
14 com.mcneel.rhinoceros.RhCore 0x00000001062d13cf CRhinoRead3dmHelper::UpdateLinkedInstanceDefinitions(CRhFileReadOptions const&) + 3281
15 com.mcneel.rhinoceros.RhCore 0x00000001062d32fa CRhinoDoc::Read3DM(ON_BinaryArchive&, CRhFileReadOptions&) + 2392
16 com.mcneel.rhinoceros.RhCore 0x0000000106f9a8f6 CRhDoc::Serialize(CArchive&) + 532
17 com.mcneel.rhinoceros.RhCore 0x0000000106aa0234 CDocument::OnOpenDocument(wchar_t const*) + 86
18 com.mcneel.rhinoceros.RhCore 0x0000000106fa0694 CRhDoc::OnOpenDocument(wchar_t const*) + 574
19 com.mcneel.rhinoceros.RhCore 0x0000000106f94c7c CRhinoDoc::OpenDocument(wchar_t const*, CRhinoOpenDocumentOptions const*) + 588
20 com.mcneel.rhinoceros.RhCore 0x000000010629c27d -[MRDocument readFromURL:ofType:error:] + 1191
21 com.mcneel.rhinoceros.RhCore 0x000000010629bcc6 -[MRDocument deferredReadFromURL] + 92
22 com.apple.Foundation 0x00007fff212366e7 __NSFireDelayedPerform + 415
23 com.apple.CoreFoundation 0x00007fff204a63c9 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 20
24 com.apple.CoreFoundation 0x00007fff204a5ebd __CFRunLoopDoTimer + 927
25 com.apple.CoreFoundation 0x00007fff204a5a1a __CFRunLoopDoTimers + 307
26 com.apple.CoreFoundation 0x00007fff2048c5e3 __CFRunLoopRun + 1988
27 com.apple.CoreFoundation 0x00007fff2048b75c CFRunLoopRunSpecific + 563
28 com.apple.HIToolbox 0x00007fff286ad203 RunCurrentEventLoopInMode + 292
29 com.apple.HIToolbox 0x00007fff286acf65 ReceiveNextEventCommon + 587
30 com.apple.HIToolbox 0x00007fff286acd03 _BlockUntilNextEventMatchingListInModeWithFilter + 70
31 com.apple.AppKit 0x00007fff22c87b32 _DPSNextEvent + 864
32 com.apple.AppKit 0x00007fff22c86305 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1364
33 com.apple.AppKit 0x00007fff22c78679 -[NSApplication run] + 586
34 com.apple.AppKit 0x00007fff22c4c85c NSApplicationMain + 816
35 libdyld.dylib 0x00007fff203aff3d start + 1
Thread 1:: SGen worker
0 libsystem_kernel.dylib 0x00007fff20361d4e __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff20394ea1 _pthread_cond_wait + 1298
2 libmonosgen-2.0.1.dylib 0x00000001ae4dd0f3 thread_func + 243
3 libsystem_pthread.dylib 0x00007fff20394954 _pthread_start + 224
4 libsystem_pthread.dylib 0x00007fff203904a7 thread_start + 15
Thread 2:: Finalizer
0 libsystem_kernel.dylib 0x00007fff2035f366 semaphore_wait_trap + 10
1 libmonosgen-2.0.1.dylib 0x00000001ae4879eb finalizer_thread + 315
2 libmonosgen-2.0.1.dylib 0x00000001ae442143 start_wrapper_internal + 403
3 libmonosgen-2.0.1.dylib 0x00000001ae441f8e start_wrapper + 62
4 libsystem_pthread.dylib 0x00007fff20394954 _pthread_start + 224
5 libsystem_pthread.dylib 0x00007fff203904a7 thread_start + 15
Thread 3:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff2035f32a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff2035f69c mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff2048dc6f __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff2048c34f __CFRunLoopRun + 1328
4 com.apple.CoreFoundation 0x00007fff2048b75c CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22e0dbaa _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff20394954 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff203904a7 thread_start + 15
Thread 4:: Thread Pool Worker
0 libsystem_kernel.dylib 0x00007fff2035f37e semaphore_timedwait_trap + 10
1 libmonosgen-2.0.1.dylib 0x00000001ae36e8b4 worker_thread + 804
Thread 5:: Thread Pool Worker
Thread 6:: Thread Pool Worker
Thread 7:: Thread Pool Worker
Thread 8:: Thread Pool Worker
Thread 9:: Thread Pool Worker
Thread 10:: Thread Pool Worker
Thread 11:: Timer-Scheduler
1 libsystem_pthread.dylib 0x00007fff20394ed7 _pthread_cond_wait + 1352
2 libmonosgen-2.0.1.dylib 0x00000001ae4f0651 mono_os_cond_timedwait + 81
3 libmonosgen-2.0.1.dylib 0x00000001ae44f456 mono_w32handle_timedwait_signal_handle + 262
4 libmonosgen-2.0.1.dylib 0x00000001ae44f1cf mono_w32handle_wait_one + 607
5 libmonosgen-2.0.1.dylib 0x00000001ae44f58b mono_w32handle_wait_multiple + 203
6 libmonosgen-2.0.1.dylib 0x00000001ae43b4d6 ves_icall_System_Threading_WaitHandle_Wait_internal + 198
7 libmonosgen-2.0.1.dylib 0x00000001ae3cde38 ves_icall_System_Threading_WaitHandle_Wait_internal_raw + 104
8 ??? 0x00000001b4ea34e9 0 + 7330215145
9 ??? 0x00000001b4ea3123 0 + 7330214179
10 ??? 0x00000001b6ac9f68 0 + 7359733608
11 ??? 0x00000001b6a7164b 0 + 7359370827
12 libmonosgen-2.0.1.dylib 0x00000001ae1fabf1 mono_jit_runtime_invoke + 1617
13 libmonosgen-2.0.1.dylib 0x00000001ae4154f8 mono_runtime_invoke_checked + 136
14 libmonosgen-2.0.1.dylib 0x00000001ae41c76c mono_runtime_delegate_try_invoke + 220
15 libmonosgen-2.0.1.dylib 0x00000001ae442237 start_wrapper_internal + 647
16 libmonosgen-2.0.1.dylib 0x00000001ae441f8e start_wrapper + 62
17 libsystem_pthread.dylib 0x00007fff20394954 _pthread_start + 224
18 libsystem_pthread.dylib 0x00007fff203904a7 thread_start + 15
Thread 12:: Thread Pool I/O Selector
0 libsystem_kernel.dylib 0x00007fff2036766e __select + 10
1 libmonosgen-2.0.1.dylib 0x00000001ae4f3fe2 mono_poll + 562
2 libmonosgen-2.0.1.dylib 0x00000001ae44704c poll_event_wait + 220
3 libmonosgen-2.0.1.dylib 0x00000001ae446aa7 selector_thread + 1527
4 libmonosgen-2.0.1.dylib 0x00000001ae442143 start_wrapper_internal + 403
5 libmonosgen-2.0.1.dylib 0x00000001ae441f8e start_wrapper + 62
Thread 13:: Thread Pool Worker
Thread 14:: tid_1d70f
5 com.apple.CoreFoundation 0x00007fff20512062 CFRunLoopRun + 40
6 libmono-native.0.dylib 0x00000001b342d89c ves_icall_Interop_RunLoop_CFRunLoopRun + 76
7 ??? 0x00000001be31830c 0 + 7485883148
8 ??? 0x00000001b6ac9fa7 0 + 7359733671
9 ??? 0x00000001b6a7164b 0 + 7359370827
10 libmonosgen-2.0.1.dylib 0x00000001ae1fabf1 mono_jit_runtime_invoke + 1617
11 libmonosgen-2.0.1.dylib 0x00000001ae4154f8 mono_runtime_invoke_checked + 136
12 libmonosgen-2.0.1.dylib 0x00000001ae41c76c mono_runtime_delegate_try_invoke + 220
13 libmonosgen-2.0.1.dylib 0x00000001ae442237 start_wrapper_internal + 647
14 libmonosgen-2.0.1.dylib 0x00000001ae441f8e start_wrapper + 62
15 libsystem_pthread.dylib 0x00007fff20394954 _pthread_start + 224
16 libsystem_pthread.dylib 0x00007fff203904a7 thread_start + 15
Thread 15:: tid_1100f
3 libmonosgen-2.0.1.dylib 0x00000001ae4fd2d0 mono_thread_info_sleep + 672
4 libmonosgen-2.0.1.dylib 0x00000001ae36def6 monitor_thread + 390
5 libmonosgen-2.0.1.dylib 0x00000001ae442143 start_wrapper_internal + 403
Thread 16:
0 libsystem_pthread.dylib 0x00007fff20390484 start_wqthread + 0
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000112e70e00 rcx: 0x00007ffee9a13f78 rdx: 0x0000000000000000
rdi: 0x0000000000000103 rsi: 0x0000000000000006 rbp: 0x00007ffee9a13fa0 rsp: 0x00007ffee9a13f78
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000112e70e00 r11: 0x0000000000000246
r12: 0x0000000000000103 r13: 0x00006000079281c0 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff20365946 rfl: 0x0000000000000246 cr2: 0x00000001be8a4000
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Thread 0 instruction stream not available.
Thread 0 last branch register state not available.
Timestamp Thread Type Activity PID TTL
2021-05-10 19:54:18.940401+0100 0x9424 Default 0x14377 1233 0 <RhCore-[MRDocumentController openTemplateDocumentWithContentsOfURL:display:error:]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] open template 'Small Objects - Millimeters.3dm' 2021-05-10 19:54:19.134218+0100 0x9424 Default 0x14377 1233 0 <RhCore-[MRDocumentController addDocument:]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Add document: ‘Untitled’ (…/(null))
2021-05-10 19:54:19.134807+0100 0x9424 Default 0x14377 1233 0 <RhCore-[MRDocumentController logOpenDocuments]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Open documents: (1) 'Untitled' (.../(null)) 2021-05-10 19:54:24.788271+0100 0x9424 Default 0x0 1233 0 <RhCore-[MRRhinoMonitor startCommand:]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Start command: ‘SystemInfo’
2021-05-10 19:54:25.086502+0100 0x9424 Default 0x0 1233 0 <RhCoreCRhCrashDumpCommandSpy::~CRhCrashDumpCommandSpy()> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Finish command: 'SystemInfo' 2021-05-10 19:55:19.357379+0100 0x9424 Default 0x0 1233 0 <RhCore-[MRDocumentController addDocument:]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Add document: ‘VRay127WardourCompiled.3dm’ (…/VRay127WardourCompiled.3dm)
2021-05-10 19:55:19.358206+0100 0x9424 Default 0x0 1233 0 <RhCore`-[MRDocumentController logOpenDocuments]> Rhinoceros: (RhCore) [com.mcneel.rhinoceros:always] Open documents: (2) ‘Untitled’ (…/(null)), ‘VRay127WardourCompiled.3dm’ (…/VRay127WardourCompiled.3dm)
Thanks - that looks like the right info - do you get the Rhino/McNeel crash report UI when you next start Rhino? If you send that, then it goes through some pipeline or other that makes it easier for the developers to get at it.
Sent it, thanks!
Can you use Import instead to open the file causing this issue? Make a new blank file and then run the Import command to try.
Hi Joshua,
Thanks for sending all the files.
It turns out that only your parent file is 35MB, and the sum of your linked blocks in over 700MB.
The file size is a sum of the current model and all the linked blocks ~ so the real file size is over 750MB
Because you are using Mac, the WorkSession option is not available, but on Windows it is one option instead of a linked block that might have helped.
Large files use a lot of CPU and GPU resources.
However, we were able to repeat the crash you were experiencing.
It is logged as RH-64193. Because of your files are attached, this is not for public viewing.
However, you will be notified when there is a fixed.
Thanks for your diligence in sending us the whole set of files.
Sincerely,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
Strangely enough, that works, thanks!!
