Rhino export to dwg skipps pictureframes
I want to export a project to a dwg file. It is mostly background images with some texts here and there. I did such exports in the past, but this time I got “PictureFrame” skipped. When I open dwg file in dwgviewer, all the images are gone. What I did:
I copied all images to one folder
I manually changed the file path of every image to the one in the common folder
I saved the 3dm file into the same folder and then I exported to dwg.
In the past I had issues with other programs not seeing pictures, but they at least displayed white rectangle, and Rhino project was fine. Now, when I open dwg export, even Rhino can not see the images.
I read this post: Picture (PictureFrame) export to DWG
And I fall into its description: when importing images for the first time, I had them in a different folders then the project file. The question: is it possible to somehow fix it?
