I am trying to import drawings from SW to Rhino via .dwg format. There is a problem with the picture display. I have pictures on my solidworks drawing but most of them would dissapear when I open the .dwg with Rhino…
Same with the .dfx format.
Any idea?
Thanks
dwg does not support images,
you’ll need to import your dwg file, then place the images using the picture command in rhino
Thanks @theoutside ,
I found a workaround to that; if I simply rotate the pictures on my solidworks documents I will automatically be alerted that some pictures were modificated and that they will be saved in .bmp separately from the new .dwg document during exportation. The pictures will then appear correctly.
Hope this can help
