Hello dear forum members, I think I messed up a few settings as a result of a wrong click. When I export the stl file, it reduces the number of corners and makes smooth surfaces very bad. Which setting do I need to correct?
Hi Alper -
When you export as STL, there will be a dialog box where you can input the tolerance and then check the preview. You can also go to detailed controls from that dialog. Alternatively, you can first mesh an object and then export the mesh.
