Rhino export STL surface is not smooth
Hi, I exported this file to STL for 3d printing, but no matter what I try, I keep getting these unclean triangles on my surfaces. The surfaces are all flat, nothing too complex.
test_2.3dm (4.1 MB)
Even without opening your file, I would say that your objects are too far from the origin…
OK, let’s open it now.
Answer: Yes. Here are the coordinates of the corner of one of your enclosing boxes:
Move the objects close to the world origin and re-export, I’m sure the .stl will be fine (assuming correct export options).
It works. Thank you so much!
