Rhino Error reporting upon startup
I’ve been using Rhino 6 for a few weeks with no issues. recently after a windows 10 update I’ve been getting an error message upon opening rhino.The error reads “Rhino encountered a problem and needs to close. Please send this confidential error report now”.
Does anybody know how this can be resolved?
Ali
Send the report!
Does Rhino start in Safemode?
Use the Windows 10 Search tool to look for “Rhino 6 in safe mode”
This blocks OpenGL and plug-ins; either of which can cause a startup crash.
yes. it seems to open fine in safe mode.
That’s a general indication of possible bad display drivers or a bad plug-in.
Based on recent Windows updates, my best guess is display drivers.
Run the Windows Device Manager
Expand the Display Adapters section
Right click on the graphics card > Properties > Driver tab
Take a screenshot
You may have two Display Adapters. Do the same steps for that one too.
Return the screenshot(s) in a reply.
We’ll go from there.
here is the screenshot
Yup.
That’s a very old AMD driver and is most likely the cause of the problem.
Here’s a link to the AMD page for drivers for that card.
Download and install the update.
https://www.amd.com/en/support/graphics/amd-radeon-r7-series/amd-radeon-r7-400-series/amd-radeon-r7-m445
Any luck?
Thank you so much John! that seemed to work perfectly! :slight_smile:
Ali
Excellent.
I am concerned that the Intel HD 620 is also old.
Hmm I’ll look into updating that one as well then.
Here’s a link to the current drivers:
If your computer complains about that new driver not being validated for your computer, here’s how to fix that too:
hello, would u like to help me? ive got the same problem
Hello- please see the solutions noted above and if these do not help, please post (copy/paste) the output from the Rhino command SystemInfo
hi,
please help me
I am in the same problem with my Rhino 6. what should I do?
hi @Indra_Wansyah can you start your Rhino in safe mode and see if the problem persists? If it does run, pls run _SystemInfo and post back the results.
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
License details: Stand-Alone
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 8GB, Driver date: 5-6-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2025
Driver Version: 32.0.15.7640
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24170.13001
hi, check me plz?
Hi Nell -
The current version of Rhino 8 is SR 19! Please update to that version.
