Rhino Disables my Wi-Fi
I’ve been having issues with Rhino killing my Wi-Fi connection whenever I open it but when I close it everything turns back to normal and my wifi works again. I already tried the DisableInternetAccess Method and it doesn’t work. How do I fix this issue?
Run the Rhino command SustemInfo and post the results.
Hi @Demetrio_Castillo apart from the requested _SystemInfo, can you see if any of the suggestions in this thread work for you?
What kind of computer brand/model are you using?
Gijs missed the link, several possibilities, getting your SystemInfo will narrow it down.
Essentially there is something in your computer setup that Rhino is bringing to light, such as the MSI dual band or the Levono Network boost mentioned in the thread.
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Educational, build 2023-06-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 6-23-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2023
Driver Version: 31.0.15.3640
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\DJ\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22353.1023
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
I have a Dell G7 7500
System Info:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
See if you have smartbyte installed…
