Rhino disconnects me from my wifi 5ghz band network
I am using Rhino 7 (for windows) and windows 11 both up to date. As soon as I open Rhino it disconnects me from my wifi network. The network is still on the list of available networks but I can’t connect to it anymore unless I close Rhino. I am using a 5ghz band at home. This problem does not happen if, for example, I connect to a shared wifi point from my mobile phone.
Curiously, when opening Rhino in safe mode connection remains OK, connected, until I open the properties menu and then immediately disconnect from the network, so I need to close rhino in order to be able to connect to my wifi network again.
Any idea what is going on?
Please any help would be welcome!!
Rhino 7 SR19 2022-6-14 (Rhino 7, 7.19.22165.13001, Git hash:master @ 303aecd3f1907d87fe49f88f695c02fb790b1e31)
License type: Educational, build 2022-06-14
License details: Stand-Alone
Windows 10 (10.0.22000 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 5-19-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.96
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-19-2022
Driver Version: 30.0.15.1296
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\dSz\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.12\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.19.22165.13001
Is this an MSI machine? Rhino kills my internet connection - #26 by hailey
Hi Japhy,
no, it is not…is a Dell XPS
I tried everything that is suggested in that thread. I think it is related to being connected to a 5ghz band but since I do not have the choice to do it to any other one I need to make it work with that kind of band.
Lets reboot your router. After that lets try disabling the karamba via the file>properties>plugins.
hi there,
So apparently it worked out after rebooting the router. I had already disabled the Karamba plug-in before. I did a couple of checks and for now, everything is back to normal…which is awesome.
Thanks a lot!
