My rhino is constantly crashing, when i copy it loads and on the top left it says “not responding” takes a little and then is fine. When i try to render my cpu raises to 100% and is loading to start rendering. As well as when i try to use “make2d” my cpu also goes to 100% and loads for a few minuetes and the command doesn’t end up working. I have updated my driver and not sure what’s is going on.
What does -systeminfo say?
Are you sure its actually crashing or is Rhino just busy? Give it a wait and see. Generally until you see an actual crash message, it’s just busy.
Sometimes my rhino will load and a “close program” will pop up as well as “server is busy” i get both.
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Educational, build 2023-09-24
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [81% battery remaining] ~67 minutes left
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-29-2023
Driver Version: 31.0.15.4629
Z-Buffer depth: 24 bits
Total Video Memory: 6141 MB
C:\Users\xaxal\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.5.3\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.5.3.0
C:\Users\xaxal\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
I see your laptop is unplugged, please ensure you are still using the larger card by checking the graphics settings. Soooo, you bought a laptop with hybrid graphics and rhino doesn't run right. READ THIS
Is this happening in a particular file? Please type Audit and paste the results like so…
This happens on multiple files with the same project
Document Manifest:
Texture Mapping: 0 active, 1 system.
Material: 986 active, 2 system.
Line Pattern: 0 active, 3 system.
Layer: 12 active, 1 system.
Group: none.
TextStyle: none.
Annotation Style: 5 active, 12 system.
Light: none.
Hatch Pattern: 9 active, 9 system.
Block: none.
Model Geometry: 1532 active.
Total: 2544 model components. 28 system components.
Audit Summary:
Table tally:
12 layers
5 annotation styles
0 fonts
986 rendering materials
Object tally:
1532 normal objects
0 locked objects
0 hidden objects
0 deleted objects (in undo buffer)
0 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
No errors.
Thanks, not seeing anything in your systemInfo or file audit that is unusual. Can you post the file here? If its too large or you require privacy please upload here… Rhino - Rhino Support
Why do you have the AMD and Intel denoisers installed?
I would dump them and install the NVIDIA denoiser as that what GPU you have.
I typically use the Intel denoiser to not interfere with rendering on GPU since denoising is then done on CPU.
