Hi all, My Rhino crashes, but unfortunately, this is a new rhino model and has never been named or saved before. So even I go to the autosaved file folder or the recircle bin I cannot find its autosaved file. As I understand, you can only get autosaved file when u have at least saved it once…
Am I right? Does anyone have any other trick to find the autosaved rhino file?
As shown on the screenshot, it crashes, but not close yet, do I still have any chance to get the model back?
many thanks,
For reason( I don’t know why), my dear Rhino7 never create a desktop rhino CrashDump file…
In theory, if you haven’t shut autosave off, the autosave file for a not-yet-saved file will be here:
C:\Users\<username>\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\RhinoAutosave.3dm
Yes, but as I know, if you open a new rhino file and never save it, meanwhile, the file doesn’t have a name, it won’t create any autosave file on this autosave folder, and so on the Desktop rubbish bin…
Freeze is not crash. Rhino probably won’t create any autosave when it is unresponsive, even if the freeze takes forever.
Help !!! I can locate V8 autosaves, but I can’t find V7 autosaves, I’m hoping I’ve not just lost hours of work, any assistance much appreciated (was working happily away and Rhino just closed, no freeze, ot hang up, just closed ?)
After each AutoSave the previous one gets sent to the Recycle Bin, where you should find your previous iterations.
@Japhy yes I remembered finally to check the Recycle Bin, thank goodness! Only lost about 30 minutes of work , thanks for chippin in
