How to find the unsave file of Rhino 6.0
My unsaved file(doing with 6.0 version) is not be seen in the following path:
C:\Users\lance\AppData\Local\McNeel\Rhinoceros\6.0\AutoSave\RhinoAutosave.3dm
There is no File in the `Folder of 6.0. The folder 6.0 is empty
what should I do ?
Check your Recycle Bin, you may find it hidden there :slight_smile:
You are not giving much information so, a few questions:
  • Did Rhino crash during a modeling session and you are looking to recover some of your work?
  • Is Autosave enabled in Rhino Options > Files?
  • Had you been modeling for longer than the time that is specified in those setting?
  • And finally - what is the file path that is specified there?
Note that if you exit Rhino normally and do not save, there will be no autosave file.
I have the same problem!
  • yes it crashed
  • yes it is enabled
  • yes been modeling for the whole day ( i even noticed the command history say " autosave successfully" or something at one point)
  • Ive tried every command path and the recycle bin with no luck. I just wont believe that it is all gone for the whole day. It must have managed to save once.
Please help Iā€™m so frustrated :(((
