When using the lasso tool, the selection will extend beyond the visible limits of the clipping plane. This is also true when using the command modifiers Ctrl + Shift for Subobject selection. Regular selection will not extend past the clipping plane limit.
Hi Mason, we’re primarily focused on finishing up Rhino 7 at the moment, and are fixing bugs as they come in. Rhino 6 bug fixes are mostly limited to critical issues, not annoyances.
While some that are not experiencing the bug might find it annoying, i find it potentially detrimental to my work. This can potentially lead to important data being deleted from the file without the knowledge of the user, and without the visual indicator of the clipped off objects showing in the selection set, there isnt a way to be aware that this is happening or not.
