Rhino beta Not Responding when adding to group
The freeze happens if i load up the AI panel and then add to group
TRI18 261005BC side building R9.rar (2.0 MB)
here’s a transfer link
I tried _AddToGroup on a simple example with just a few boxes and it seems to work fine.
Rhino 9 BETA, 9.0.26272.12303
System Info
Rhino 9 SR0 2026-9-29 (Rhino 9 BETA, 9.0.26272.12303, Git hash:master @ b5f5102690615c89acabfc68e24eae200f3d735b)
License type: Commercial, build 2026-09-29
License details: Cloud Zoo
Expires on: 2026-11-13
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 128GB)
.NET 10.0.12
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 9-16-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Import_SolidWorks.rhp “Solidworks Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
@martinsiegrist , please also try with the file i attached, thank you!
I don’t download *.rar or *.zip compressed files.
i also placed a transfer link
No freeze here with this file.
What build are you on? It might help pasting the system info in the first post…
all i did was to generate the building using the AI panel, and then modified one wall and when i add it to group i get the freeze
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 10.0.8
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
Hybrid graphics configuration using DirectX
  Primary display: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-14-2025 (M-D-Y).
        - Secondary monitor is laptop's integrated screen or built-in port
  AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 8-13-2024 (M-D-Y).
    > Integrated accelerated graphics device with 5 adapter port(s)
        - Windows Main Display is laptop's integrated screen or built-in port
DirectX Settings
  Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
  C:\Users\bogda\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\\D5Conv.rhp	"D5 Live Sync for Rhino"
  C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp	"Commands"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp	"RhinoAI"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp	"3DxRhino.9"
  C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp	"UpdatesAndStatistics"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp	"MeshCommands"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp	"RhinoCodePlugin"	9.0.26272.12303
  C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp	"SectionTools"
  C:\Program Files\Rhino 9 WIP\Plug-ins\NamedPositions.rhp	"Named Position"
  C:\Users\bogda\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp	"PanelingTools"
@martinsiegrist , try loading up the AIpanel and then try to add to group.
I don’t have an AI agent installed.
Did you try with enscape unloaded?
you don’t need to have an AI agent installed, just run the AIPanel command
Enscape is not even installed on beta, it’s just the toolbar synchronized from Rhino 8…
no issues here adding to your group, with or without the RhinoAi Panel.
I also tried in the 9-23 build and not seeing an issue. This looks isolated to your environment.
I can replicate it now even without the AI panel… totally something on my environment.
What else should I try?
Looking at your systemInfo two things stand out.
We should try in SafeMode (sans 3rd party plugins)
and update your video driver..
thanks for yor help @Japhy , but things are still not ok.
i updated the graphics driver and also took out D5 from loading at startup.
restarted computer.
there is something related to the AI panel, as i was noticing before.
please check the video below:
  • first i add to group and it works fine
  • then i load up AI panel and try again to add to group - and i get again not responding
    (it is actually the selection itself that freezes rhino, not necessary related to adding to group)
do you have other suggestions?
could it be something related to codex, or to ai panel history?
thanks!
Can you repeat in SafeMode?
yes, in safe mode with the ai panel it freezes, without it, it doesn’t
Your model has one group with 3063 objects in it, so a single click selects all of them, and with the AI panel open each of those selections
does extra work. Until it’s fixed, close the AI panel while selecting in this file, or split that big group up. RH-99277 AI panel makes selecting large
groups very slow
  • once i open the AI panel for the first time, selecting will be slow, even if i close it.
RH-99277 is fixed in Rhino BETA
@brian & @Japhy I’ve been using the Rhino AI feature the last few days and it’s been a great experience so far but in some situations I have a feeling loading a file takes longer and Rhino somehow freezes for a moment? Also when opening the script editor…
