What is BETA? We’re not adding any new features, nor are we making significant changes to the UI. We’re also done breaking the APIs, so plug-ins written for this Beta will work in the commercial release of Rhino 6.
For the next few builds, we’ll be wrapping up documentation, localization, and working with our third-party developers to get their plug-ins ported to Rhino 6.
New this week:
Crash:
- Geometry Core: :Min – Access Denied (RH-42767)
Bug:
- Annotation: Only created in World XY CPlane (RH-42694)
- Annotation: DimAngular: Angular dimension text location different in V6 than V5 (RH-42029)
- BlendCrv: Edit messy (RH-42806)
- Build Process: Add version information to rhinocommon sdk docs (RH-35275)
- ChamferEdge: Fails in V6 OK in V5 (RH-42522)
- Cycles: Rendered pretty good, Raytraced (Cycles) black (RH-42541)
- DimArea: Does not accept preselection (RH-42685)
- Display:
- Decals are broken in Rendered mode (RH-42813)
- Reflections with non-white reflectivity do not work correctly in rendered mode (RH-42860)
- Reflections with non-white reflectivity do not work correctly in rendered mode (RH-42904)
- Skylight shadow can have circular artifacts on zoomed-in models (RH-42780)
- atio6axx – Access Denied (RH-42771)
- Docking Tabs: License manager fails with error 0 results in trashed docking configuration (RH-42612)
- EditPythonScript: Python editor showing up on taskbar (RH-42764)
- Elevator Mode: Constraint UI change? (RH-42683)
- File IO: PDF import does not maintain text when using the text option (RH-10123)
- Grasshopper:
- Grasshopper: Components: Rhino crash while I set a value to the Distance of OffsetSrf component (RH-42622)
- Help: Missing verb “edit” in Rhino Help - Environments.html (RH-42342)
- Join: Make the default ‘Yes’ (RH-42792)
- Lasso: Nested Lasso selects subobjects when whole objects are expected (RH-42672)
- Licensing and Validation:
- Localization: Typos in en-us toolbar_content.xml (RH-42765)
- MacroEditor: Not setting focus to Rhino when a macro is run (RH-42668)
- Crash fix: Rhino – Access Denied (RH-42768)
- RDK:
- Rebuild: Make the point count match the degree (RH-17918)
- Rendering: Materials: Duplicated material replaces original (RH-42802)
- SDK:
- Tab Constraint: Constrained direction is overridden by Cartesian coordinate (change from v5 behavior) (RH-42677)
- TextObject: Multi-line strings in scripted TextObject command (RH-42772)
- Toolbar:
Enhancement:
- Grasshopper: GH Surface Param Does Not Accept Extrusion (RH-42664)
Download Now and report any problems in this forum.
