Rhino BETA 2017-Nov-14 Now Available
Download Rhino BETA now!
What is BETA? We’re not adding any new features, nor are we making significant changes to the UI. We’re also done breaking the APIs, so plug-ins written for this Beta will work in the commercial release of Rhino 6.
For the next few builds, we’ll be wrapping up documentation, localization, and working with our third-party developers to get their plug-ins ported to Rhino 6.
New this week:
Bug Fixes:
  • Annotation: Dot: Text unreadable when dots are blue (RH-42429)
  • ApplyShutLining: Turning off the crv removes the render mesh (RH-42386)
  • Cycles:
    • Doesn’t respect the Transparent background option (RH-42413)
    • Properties panel doesn’t update when Raytraced is running (RH-42334)
    • Setting display to Raytraced crashes Rhino (RH-42332)
    • StartResolution default value is bad (zero) (RH-42376)
  • Display:
    • Can’t drag and drop material onto fully transparent object (RH-42313)
    • Cannot override locked color of curves (RH-42357)
    • Curves in X-Ray after Glass assignment (RH-42333)
    • Rhino crashes when loading the attached file. (RH-42428)
    • Video driver information is always wrong or “Not Available” (RH-42488)
  • File IO:
    • Font size tune up in PDF export (RH-42397)
    • Stacked, multi-line text from DWG is not stacked or positioned correctly (RH-28474)
  • Fin: Fin on twisted degree 1 surfaces (RH-42324)
  • Grasshopper: Mesh naked edges are too difficult to merge. (RH-40126)
  • Grasshopper: Components: Construct Mesh in GH (RH-37837)
  • Help:
    • String possibly missing (?) in BooleanIntersection.htm (RH-42420)
    • Wrong syntax in Options (RH-42423)
  • Installer:
    • Beta Dujour installer doesn’t install on top of old WIP/6.x build (RH-42416)
    • Rhino BETA shortcut icon says “WIP” (RH-42402)
  • Licensing and Validation:
    • After user enters their license key, offer to add it to their Rhino account (RH-42442)
    • Language for adding license to Rhino account (RH-42502)
    • Rhino Commercial Build failure (RH-42436)
  • Localization: “Edit selection” button in SelConnectedMeshFaces (select connected mesh faces) dialog is not aligned with the other two controls. (RH-42445)
  • No Subsystem: Search Box localization for Name, Notes and Tags (RH-42203)
  • OffsetMesh: Makes inside-out closed meshes (RH-42446)
  • Panels:
    • Memory leak in Rhino 6: CRhinoUiDockBarTab::~CRhinoUiDockBarTab rhinotabbeddockbar.cpp Line 130 (RH-42454)
    • RhinoUiShowDockbarTab() passes a bad parameter (RH-42355)
  • Print: Vector printing misplaces dimension text (RH-42383)
  • RDK:
    • Memory leak in CRhRdkContentNavigator::Add (RH-42457)
    • Panels with edit box may cause Rhino to hang (RH-42496)
  • Rendering: Materials: Appear grey in viewports (RH-42395)
  • Rendering: Realtime SDK: Printing through realtime display pipeline doesn’t work properly (RH-41970)
  • SDK:
    • Rhino C++ SDK should include the license agreement (RH-42437)
    • Rhino C/C++ SDK installer folder incorrect (RH-42439)
    • Rhino C/C++ SDK installer needs updated text (RH-42438)
  • SDK: RhinoCommon: InstanceDefinition.UpdateType returns obsolete type (RH-42250)
  • SelChain: SelChain and mesh objects (RH-42145)
  • Selection: SelNone does not work transparently (RH-30328)
  • Shade: Rendered mode does not match (RH-42194)
  • Toolbar: I do not see the Object Osnap Between (RH-35063)
  • UntrimHoles: UntrimHoles deletes wrong hole (RH-42367)
  • ViewCaptureToClipboard: Doesn’t respect the sample count (RH-42339)
  • ViewCaptureToFile: JPG quality different that V5 (RH-41818)
  • Viewports: Redrawing of viewports works incorrectly (RH-42258)
  • Volume: Mass Properties regression tests failing (RH-42098)
Download Now and report any problems in this forum.
A post was split to a new topic: Beta fails to start
A post was split to a new topic: NGon mesh preview in Grasshopper broken
A post was split to a new topic: Selection broken in Rhino Cycles
3 posts were split to a new topic: Rhino BETA feature: Curved Leaders
A post was merged into an existing topic: Beta fails to start
Is there an EULA for this release? I need it to work with our IT department to get this release installed. Thank you very much.
No change
http://files.na.mcneel.com/rhino/5.0/docs/rh50_eula.pdf
Thank you Bob.
LAYOUT IMPORT BUG
When importing layouts from Rhino 5 all the text is misaligned and not formatted correctly. I know it has something to do with the reworking of the text in Rhino 6 but I am wondering if there is a way to make importing Rhino 5 layout templates more streamlined. It would be a lot of work to remaking these.
You are posting this under the announcement for the November 14th beta. Which version are you running now? There have been fixes for text after November 14th…
