Rhino BETA 21-Dec-2017 Available
Download Rhino BETA now!
What is BETA? We’re not adding any new features, nor are we making significant changes to the UI. We’re also done breaking the APIs, so plug-ins written for this Beta will work in the commercial release of Rhino 6.
For the next few builds, we’ll be wrapping up documentation, localization, and working with our third-party developers to get their plug-ins ported to Rhino 6.
New this week:
Performance Problem:
  • PrintPreview: Paper size selection may hang in TestPrintDialog (RH-42704)
Crash:
  • Display: OpenGL 3.3: GPU Tessellation completely locks up entire computer (RH-42887)
  • OneView: Crash bug in OneView (RH-43071)
  • SDK: RhinoCommon: Rhino crashes if Rendered mode is active when making a material (RH-43033)
Bug:
  • Annotation: DimRadial: The RichTextArea is almost hidden by default in the edit dialogs of the radius and diameter dimensions (RH-42965)
  • Annotation: Text wrapping error (RH-42972)
  • Annotation: Leader: Add endpoint osnaps to leader curves (RH-43107)
  • AutoSave: On large captures (RH-43148)
  • Annotation: Hatch:
    • Defective hatch pattern (RH-42994)
    • Hatch pattern rotation wrong with rotated cplane (RH-42983)
  • Bend: No preview for points (RH-42893)
  • Contour: Contour by Polar (RH-2990)
  • DPI Aware: Usage Statistics dialog too large (RH-42923)
  • Display:
    • Block instance point not displayed (RH-43025)
    • Edges missing far from the origin (RH-43074)
    • Some points show (RH-43076)
    • Caching is producing bad results (RH-42645)
    • Glossy reflection environment should visually match corresponding Cycles output (RH-42901)
    • Selected point cloud depth problem (RH-40233)
    • Text shows artifacts (on VMWare) (RH-42711)
    • Turning off shadows turns off IBL (RH-43016)
  • Drag: Dragging unselected objects (RH-43078)
  • DupBorder: Leaves out a small edge segment (RH-42789)
  • EditPythonScript: On top of everything (RH-42962)
  • ExtractConnectedmeshFaces:
  • Grasshopper: Patch component broken (RH-42596)
  • File IO: PDF files are not compressed (RH-42956)
  • Grasshopper:
  • Help: The definition of the Property override set is missing in the Help (RH-42851)
  • Installer:
    • Direct users to website on install failure (RH-42867)
    • WIP in Installer Title (RH-42922)
  • Layout: Need option for PDF when creating a layout (RH-42955)
  • Licensing and Validation:
  • Localization:
    • “Use your license anywhere.” in validation client appears in English only. (RH-43075)
    • Insufficient text display in German Beta (RH-43153)
    • Snapshots Save/Restore partial/Edit dialog needs localization (RH-42858)
    • The example in SubCrv help topic can not be implemented (RH-42852)
    • Unlocalized string in German and Italian Beta (RH-42760)
    • Unlocalized strings in CPlane screen and Active display modes (Italian) (RH-42944)
  • Loft: Loft - Special case for converging curves (RH-42892)
  • Menu: “Download Plug-ins…” help menu point to Food4Rhino (RH-42928)
  • No Subsystem:
    • Assert when closing modal render window (RhinoRender) (RH-43013)
    • Clipping plane - Meshes and wires are clipped using a different bias (RH-42679)
    • Metal reflections are too sharp by default (RH-42836)
    • ViewCapture on Raytraced prints glitched “Generating preview” string. (RH-42233)
  • OpenNURBS: ON_DebugBreak() in openNURBS on startup (RH-43011)
  • PluginManager:
    • “Error loading template” (RH-43182)
    • Create UpgradePlugins command (RH-42827)
    • Ignore neon when checking for Plug-in Updates (RH-43135)
  • Print:
    • Hide all non-core PDF printers (RH-42921)
    • Match line type definition ignored (RH-43019)
  • Rendering: Materials: Polished materials use 100% polish - which is too sharp (RH-42903)
  • Rendering: Realtime SDK: Raytraced degraded OpenGL crappy (RH-42784)
  • RhinoStart: Crash on startup when checking for updated plug-ins (RH-43146)
  • SDK: RhinoCommon: Flamingo materials are not allowing textures to be added (RH-42971)
  • Toolbar: Typo in ‘Remove naked micro edges’ macro (RH-43029)
  • UDT: default CP on for curve creates disconnected CageEdit box (RH-42727)
  • UseExtrusions: UseExtrusion Command Prompt Confusion (RH-42615)
  • ViewCaptureToClipboard: Raytraced transparency in ViewCapture* broken (RH-43043)
  • VolumeMoments: Principal Volume Moments (RH-42797)
  • Zebra: No stripe direction in Rendered (RH-42680)
  • No Subsystem: Metal colors “picked by an engineer” (RH-43131)
  • Rendering: Materials: 3ds file doesn’t display material textures when opened (RH-42952)
  • UI Cleanup: -SetDisplayMode Rendered and Raytraced are the same (RH-43005)
  • Update System: Throws an exception when starting Rhino (RH-43130)
Enhancement:
  • UDT: Using Taper and Stretch on control points (RH-42954)
Download Now and report any problems in this forum.
