Hello, maybe someone knows, if I imported a .3dm file into ArchiCAD and then I transferred it through RFA & RVT to Revit, the output will be NURBS geometry?
Why do you need to run it through ArchiCAD? Couldn’t you export the NURBS surface as a DWG or SAT file and import that directly into Revit? In my experience, the best you’re going to get is a generic model/mass family.
I am interested in ArchiCAD 21 and Revit 18, maybe someone tried them, tell me, please
Output mesh only
Rhino.Inside.Revit will try and transfer as solids first, if the geometry is too complex it will use .sat import.
If you can provide a portion of your 3dm file I will setup and example workflow.
Thanks
I very much appreciated it, but I need the old versions of Revit, and .sat format give the bad results in my case, Revit don’t want to import a model in completed.
