Rhino 9 WIP | Bug | Clipping drawing creation
Hi @mary
I am experiencing a strange behavior when creating section drawings using clipping. Occasionally and seemingly at random, the clipping drawing is not displayed, but the block of the drawing is still created. Sometimes, it is ok sometimes is missing.. ?
I haven’t been able to identify any clear pattern. I tried several different approaches, but I couldn’t determine what is causing it.
Has anyone experienced something similar?
Thanks.
Hi @tcisar,
Thank you for the video.
Can you send us the model? tech@mcneel.com?
Reference this forum post link and include Attn. Mary.
I am not sure if it is being clipped by another clipping section or if it is related to the current layer or the style of clipping drawings or something else.
Also can you post your Rhino SystemInfo?
Open Rhino. Type SystemInfo command. Copy and paste the text results into your reply.
We look forward to getting the model here to see if we can duplicate it.
Sincerely,
Mary Ann Fugier
Hi @mary
Thank you very much. I’m sending the file as recommended.
I tested the behavior. I recreated the sections—some work without any problem, while others disappear, although the block is created. After inserting the block into model space, they appear, but for example they cannot be updated.
System info:
System info.txt (5.7 KB)
Hi @tcisar,
I was able to duplicate this with your file on Windows and Mac.
I also found another crash bug trying to chance the display color of a clipping section.
I logged:
We should hear back in 2-3 days once the developers have had time to review. But it is in the system now.
Sincerely,
Mary Ann Fugier
@mary Thank you very much for your support!
Hi @tcisar,
We appreciate your letting is know and sharing your model/process.
Great to get these fixed and working sooner rather than later.
You will be notified here when there is a fix to test.
Best,
Mary Ann Fugier
Hi @mary , is there any chance we could get a fix from the developers? Many thanks!
@tcisar
That is the plan, that is our process.
RH-93903 is fixed in Rhino WIP
