In this model, 3D-model on the left, clipping plane drawing on the right.
When using left drag window over the clipping drawing, it also selects part of the model. Those parts seem to be grouped (in the 3D model). This must be some kind of bug in the clipping drawing generation. The clipping drawing should be 100% disconnected from the 3D-model (I presume) … ?
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 96GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 5-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.85
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-13-2024
Driver Version: 32.0.15.5585
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\RhinoTerrain_7\Bin\RhinoDB.rhp “RhinoDB”
C:\Users\Erik\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
This post also shows a behaviour that is quite irritating …
The insertion point of the clippingdrawing is “the center” of whatever geometry is included. Meaning that if the extents of the geometry changes, “the center” changes. Meaning that it is virtually impossible to insert a new clippingdrawing on exactly the same spot.
What if some geometry needs to be added manually afterwards?
And why on earth is the clippingdrawing always inserted according to the wcs? It should of course be inserted to whatever construction plane being active. And updates should be to the same position.
Both these things are MAJOR issues making life very complicated.
