Rhino 9 WIP Available Now!
Rhino 9 WIP (9.0.25322) is now available for Windows and Mac
Bugs Fixed:
  • The contrast of the content ui's are quite high. (RH-83954)
  • Annotation: Hatch:
    • Creating a hatch clears previous undo stacks (RH-90457)
    • Patterns cannot be deleted (RH-90249)
    • Hatch properties can not stick to “All Hatches” (RH-90448)
  • ClippingDrawings:
  • Eto: Do not let right-click trigger rename in list mode (RH-90384)
  • GlobalEdgeContinuity:
  • Help: for Patch: internal constraints (RH-90137)
  • MissingAssets: Tringle icon is getting clipped (RH-90389)
  • Options: Display Mode options look different on Mac vs. Windows (RH-87991)
  • PackageManager: Packages should be curated (RH-89937)
Enhancements:
  • Align: Align Will Not Use InfinitePlane (RH-90437)
  • ClippingDrawings: Output hatch inherits clipped object's section style properties (RH-89775)
  • Rotate3D: Allows using a curve segment to define rotation axis (RH-90365)
  • ShowDir: Better UV indicators (RH-56040)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Grid and list view icons don't fit on Mac (RH-90467)
  • Interface: Missing Assets - font list not updating after BulkReplace (RH-90340)
  • OSnap:Dialog: OSnap: Dialog: Control Provides Inaccessible Options (RH-90223)
  • UI Cleanup:
    • LiquidGlass: Step Import Options: Padding (RH-90353)
    • LiquidGlass: Acad Import: touching radio buttons (RH-90352)
    • LiquidGlass: BlendSrf: misaligned radiobuttons (RH-90348)
    • UI: LiquidGlass: ModelingAids: Gumball Tab (RH-90349)
Windows-Only Changes
Bugs Fixed:
  • Annotation: Hatch: Current pattern name displays with different font weight (RH-90449)
  • Menu: Recent files - include rws files (RH-34856)
