Rhino 8 "Zoom Selected" not working
Hi, I use the “Zoom Selected” command a lot and I noticed that when you select multiple objects in R7 the command centers all the objects in the viewport, now with R8 I do the same but it keeps zooming out instead of centering all the objects. Is this a bug or something?
Hi Bruno - as far as I know they should work the same. Can you please run SystemInfo in Rhino and copy/paste the resaults here? Are you using a standard mouse or some other device?
Hi Pascal, this is what pops up and Im using a logitech G502 as my mouse but im just clicking the command on the side bar
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Educacional, build 2023-10-31
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2023
Driver Version: 31.0.15.3742
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23304.9001
Hi Bruno can you please try disabling VRay in Options > Plug-ins page, and then close Rhino and re-open it - does that change anything?
It doesn’t change, it keeps doing the same. If I only select 1 to 3 objects it works, but selecting more it starts to zoom out.
Hi Bruno - I am mystified - is this true with any model? If not, can you send a model that shows the problem to tech@mcneel.com, to my attention, and with a link back here in your comments?
You are right, I opened a different file and it works with multiple objects, there may be something in that particular file that is not working correctly.
I am facing similar issue. Rhino 8 doesn’t zoom when multiple objects or blocks are selected.
Hi Akshay -
Does that mean that when you start a new file from a factory-default template and create two simple lines, zoom selected does not work?
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 8 SR20 2025-6-6 (Rhino 8, 8.20.25157.13001, Git hash:master @ 73b00899cf43922900a763212f167c03dc6f27cc)
License type: Commercial, build 2025-06-06
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 8.0.17
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA RTX A5000 Laptop GPU (NVidia) Memory: 16GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Primary OpenGL: NVIDIA RTX A5000 Laptop GPU (NVidia) Memory: 16GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-10-2024
Driver Version: 31.0.15.3878
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.220\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.220.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.51.2\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.51.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.20.25157.13001
C:\Users\AMKorlekar\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.20.25157.13001
And here is a small video of what I mean.
Zooms when I select one object. But does not when I select multiple.
Hi Akshay -
In that video, the “Zoom Selected” command doesn’t appear to be used at all - which is what this thread is about!?
Have you tried that?
Sorry, it was not zoom selected but Selecting and zooming in. And yes it doesn’t give a problem when a new file is used or when simpler geometry is present. This was a mesh geometry imported in from a different format. Did that cause the issue ? Is it because the geometry is a complex mesh ?
Hi Akshay -
That is not something that can be discerned from a video. If something is file-specific, we need to get that 3dm file to see if the behavior is something that we can reproduce on our end.
