Zoom in on details Problem in Rhino 8.3
Hi.
In Rhino 8.3 When I Zoom in on the details of my project and I select an object I am not able to zoom in or out as long as I have that object selected. When I deselected I can zoom in or out. It wasn’t like this in rhino 7. I also tried Zoom window command but it didn’t work.
In the video you can see the problem. I also compared the same file in both rhino 8 and 7.
Could you please tell me how to fix this?
Thank you very much.
Hej -
I’m not able to reproduce that issue here. When you start a new file from a factory-default template and create a simple box, does the same thing happen then?
Hi.
Yes it does. I created a new template file ( Large centimeter ). The same thing happens. when I have the object selected the problem happens but when I deselected it I can zoom in or out.
Hi.
The same thing happens with a simple box. When the object is selected and I am so close to it, I am not able to zoom in or out using mouse scroll wheels or with zoom dynamic. It’s really annoying when I work on details on my Arch projects. It wasn’t like this in Rhino 7.
Could it be a bug with viewport camera clipping plane?
Normally the Zoom window command let us to reset the viewport camera but in this case it doesn’t work.
Thanks.
Here’s another example of this issue:
Hej -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti (NVidia) Memory: 8GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
Thanks.
Could you zip the settings folder in
%appdata%\McNeel\Rhinoceros\8.0
and send that to me → Rhino - Upload to Support
Hi, I’m having the same issue, have you found an answer ? I’m new to Rhino and i’m testing to see if i can adapt to this program. Thank you for your time.
Hi Inês -
Could you describe the issue in your own words?
Also, please run the Rhino SystemInfo command and copy-paste the output here.
Sure. When I’m trying to zoom in very closely on a detail while I have something selected, the screen just jumps past de thing I’m trying to zoom in on. It complicates the task of trying to select a specific point to move a selected object when it’s made of multiple selected elements. I think it happens only on the perspective view.
Here’s the system info:
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Evaluation, build 2025-02-11
License details: Cloud Zoo
Expires on: 2025-05-14
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [81% battery remaining] ~407 minutes left
Primary display and OpenGL: Intel(R) Arc™ Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5449
Primary OpenGL: Intel(R) Arc™ Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5449
> Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.5449
Driver Date: 5-12-2024
Driver Version: 31.0.101.5449
Total Video Memory: 128 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
How far are object from the world origin? What units are you using - for example millimeters?
I’m new to Rhino
On this assumption, select the object you want to zoom to, making sure it is highlighted in the viewport in yellow, and then you can: “Set View” → “Zoom Selected”. The small magnifying glass with the yellow circles.
This will change the ratio that your mouse wheel will zoom, and will also magnify the perspective view to the object(s) you have selected. Works in any view.
Soltuion that made it allot better for me
01 Updating DISPLAY DRIVERS from NVIDIA
02 Changed zoom factor
  • Navigate to View → Zoom.
  • Find Zoom Scale Factor (default is 0.90).
works for me
“Sure. When I’m trying to zoom in very closely on a detail while I have something selected, the screen just jumps past de thing I’m trying to zoom in on.”
I’m having this problem too. In other programs, wherever the mouse cursor is, zooming incrementally reduces sensitivity as the camera approaches the surface pointed at, or the CPlane point where the cursor is pointed at if it’s not pointing at any object. This is natural as it is the only way to focus on detail. In Rhino it behaves unpredictably, sometimes doing that, sometimes shooting right past objects like they aren’t even there.
Orbiting is also weird.
I had to turn this to true: Rhino.Options.View.RotateViewAroundObjectAtMouseCursor
And this to false:
Rhino.Options.View.RotateViewAroundAutoGumball
They are hidden options not exposed in the main menus, that are ubiquitous among 3D modeling programs. It’s very likely (for me indispensible) that when you’re orbiting you want to pivot the camera around where the mouse cursor is, not around selection or the active gumball.
It may be that Rhino modelers have a different way to do things concerning the default orbit mode, but the shooting-past zooming inconsistency looks like a bug. 9 WIP.
