Unable to zoom - no objects are selected. Rhino 8 bug
Hi, I am having a problem in which I have selected geometry, yet am unable to see it or use ZE or ZS to zoom onto the geometry. I am getting the following error: Unable to zoom - no objects are selected. I have seen this is some very old forums but have not found a solution. I was using version 8.13.24289.13001, uninstalled, and installed the 8.12 version below, but the issue persisted.
I also saved as Rhino7 and the issue persisted.
My camera and target values seem to be acting up as well, and I cannot reset them.
I found the following forums but was unable to find a solution.
Also, my SystemInfo:
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Educational, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.7
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-13-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\Cole\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot11RhinoPlugin (55124e8a-aa81-4be8-8e12-9f452c473970)\2.0.0.0\KeyShot11RhinoPlugin\Rhino 7\KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
C:\Users\Cole\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggKaramba\24.8.7.8\ggKaramba.rhp “ggKarambaIFC” 24.8.7.8
C:\Users\Cole\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\24.10.6.8\bullant.rhp “bullant” 24.10.6.8
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
C:\Users\Cole\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
If it is a file you can share publicly attach it here in a reply. Otherwise upload to our tech support confidentially at rhino3d.com/upload
Since you are using a very recent version of Rhino 8 you might gain some benefit from updating both your 11/13/23 Intel and 6/25/24 Nvidia video drivers.
You can also try resetting the viewports by running the _4view command twice. I recall Pascal proposing this when he suspected viewport corruption had scrambled camera and target positions.
HTH
Jeremy
I’m having the exact same problem. The _4view helped.
