@Helvetosaur Any updates forthcoming on this topic now that 8 is shipping? (Transferring Personalized Settings [McNeel Wiki])
I just purchased my upgrade the other day for the shrinkwrap alone!
It is not as streamlined as @Helvetosaur instructed anymore.
There is a whole discussion about this and Mcneel is working on it. you can try these steps for now
That article was originally written for Rhino V3 and later updated for V4, V5, V6 and V7… and for V8 I did indeed note several times in the last edit of that article that the whole system was being redesigned.
The article also mentions that transferring settings between installations of the same versions is relatively reliable, but for upgrades it might or might not work well.
In any case, V7>>V8 is nowhere near “streamlined”.
this can be a great introduction to the new Reset Command
Hey Mitch, I wasn’t looking to bust your chops on this one!
It was slightly less painful doing the settings transfer this time. All I did was copy the xml over into the 8 folder, then import my rui from 7, then activate my middle mouse toolbar, then rearrange about 12 tool bars, only took a few minutes. ![]()
I did pretty much the same… but the V7 .rui has all bitmapped icon images. I am wanting to start from scratch for that reason and a couple of others, notably to gain a much better understanding of how the new system works. I need to be able to help my clients when they start upgrading.
Any update on this? Finally jumping from 7 to 8.
I’d ideally copy all my settings, incl. aliases, display mode settings, etc. to V8…
Thank you!
Is it now possible to save all toolbar settings, including aliases and display mode settings, with one file?
It would be great to be able to synchronize the complete workspace settings in Rhino live via the Rhino login account. Is here in the community a thread for desired updates?
Yes please i reseted my harddrive and i have a hard time to reset everything, from plugins, to buttons, ect. most of it i get done but where can i finde a good tutorial how to do it properly ? Please Rhino team this is needed very often when you need to change computers!!!
And it needs to be as simple as possible. Or at least a waterproof instruction manual somewhere.
Wanted to bump this… V8 has been here for awhile, what’s the intended workflow for transferring to a new PC currently?
